imported_LittletB99
- Oct 13, 2006
- 5
I've got the weirdest problem, my bass boat with a Johnson Gt 150 runs fine whenever I've got the motor flusher hooked up to it and testing it in the driveway but whenever I get it out on the lake it will just die whenever I give it any throttle. The boat set for 5 years, I've rebuilt the carbs, replaced one bad powerpack, plugs and wires and gas filters. I've tested with a portable gas tank to rule out stuck anti-siphon valves. Whenever I've got the boat on the water, the water pump appears to be working because water is coming out of the back of motor while the boat is idleing when it is in the water or whenever it has the motor flushers hooked up. Thanks for any advise.
