Re: Champion Plug question...
If you look up the recommended plug for your engine in the Champion book, it says J8C. If you look it up in the BRP reference you find it should be J4C. Now you have a CJ8. Here's the differences:
J4C - correct plug. J=3/8" threaded section, 4 heat range, C Copper Plus design (regular)
J8C - Incorrect plug. Heat range 8 far too hot.
CJ8 - Incorrect plug. "Shorty" version of the J8C.
The plug's porcelain insulation needs to get up to a certain temperature to burn off carbon (to prevent fouling). But if it's too hot, it'll cause the fuel/air being compressed in the cylinder to pre-ignite. The resulting misfire drives up cylinder temperatures causing the piston to melt.
The "heat range" is a code for how hot the insulator is supposed to get. Different engines need different "heat range" plugs. 8 is far too hot for a 33hp and it's use will result in sever engine damage.
