PeteB_2000
- Aug 21, 2006
- 42
hiya,
i was fiddling with the fuel filter/pump, when the pump sort of fell apart :% , ive put it back together but unsuprisingly it dosent work correctly, when i pump the bulb to prime engine it all works well till the fuel thats been primed runs out then the engine stops,
if i keep pumping the primer it will keep running, ive obviously put it back together wrong but the manual dosent show an exploed view if the fuel pump, does anyone have one or can someone help please
Regards
Pete
Regards
Pete
