pons said:
We discovered after 120 Hors running, the spark plugs has to be changed, this bug has been recognized by Evinrude, also some deflectors has to be put in place in order to increase spark plugs living time.
Question : Do you know if to put in place those deflectors is a hard sophisticate job ???
Thanks for your help ?
The deflector pin kit contains new pins that are slightly longer than the original pins that came in the motor. Replacement is easy and the special removal tool comes with the kit and well as instructions. Your dealer should also order the Champion QC10WEP plugs which are the platinum-iridium construction that replace the original QC10PEPb plugs.
I don't know how it works in France, but in the USA, an authorized dealer installs the pin kit and new plugs under warranty and it doesn't cost anything.
Also the temperature profile should be checked on the computer report printout to see if a pressure relief valve should be changed. This is also in a service bulletin.
Hope this helps you out.
