I have a 1996 Nitro 150 HP Johnson outboard. The voltage regulator shorted out. I ordered a new one from Johnson. It's replacement 439561 has one less wire coming out of the top than the original one. Other than this they are identical. As there were 2 wires that connected to wires on the engine and this one has only 1. Do I hook the one wire to the 2 leads on the engine block, or do I hook the yellow wire to the red or green wire on the engine block and forget one or the other?
