:'( my jet driv's not pumping water the engine runs
no thrust what is the turbine and what kind of oil does it require
need mechanic and manual in 34952
ok everything fixed pump is no big deal need 2 make 2 sided drift to remove the 2 different sized bearings METRIC pressed in new sealed 1 side bearings
original bearings in salt water falling apart drno_503@yahoo.com
