Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
johnson seahorse 15 hp
  • johnson seahorse 15 hp
    i have a 15 model # j15rcsd and another # e5243702 i was looking to find the year of this motor . i am having trouble with it staying in gear it was poping out while driving and now will not engage at all any info would be great!!
    Re: johnson seahorse 15 hp
    The j15rcsd is a 1980. Can't find the other.
    "A manual is a cheap investment"
    Fair Winds and Following Seas
    Bill
    PTC USN ret
    • #3
      either misadjusted shift shaft, or bad clutch dog. the E would indicated an Evinrude, but can't find #
      FLORIDA GATORS
      TEBOW Country
      Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
      That is what these forums are for. Post your questions, in the appropriate Forum.
      • #4
        The model number J15RCSD...says it's a rope start "R"...CS is the year "80" and the "D" is the model run which don't mean much to us. The other number..E5243702..is the serical number given to the engine by the manufacturer. Mostly a means of identifying the engine...don't mean much to a wrench either.If the engine was popping outta' gear...like hitting a log at higher rpm, you might want to take a look at the lobes on the clutch dog and gears. Usually means they are wore to the point that they will not stay engaged at higher rpm's.If the engine is revving up and you lose forward motion at the same time, this would mean that the prop hub is likely spun.Or, is it something different?
        When in doubt...use the manual
        Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
