Just got my Johnson 40 HP started, noted grease on prop, is this normal or do I have a problem
J jbrock70 Recruit Joined Jun 1, 2006 Messages 4 Jun 3, 2006 #1 Just got my Johnson 40 HP started, noted grease on prop, is this normal or do I have a problem
C catchingmore Seaman Apprentice Joined Jun 1, 2006 Messages 37 Jun 3, 2006 #2 Re: Grease on Prop? did you run it in a bucket might be grease and oil from the engine coming out the exaust
J jbrock70 Recruit Joined Jun 1, 2006 Messages 4 Jun 3, 2006 #3 Re: Grease on Prop? No, just got it started for the first time this year, didn't run but a few seconds
C catchingmore Seaman Apprentice Joined Jun 1, 2006 Messages 37 Jun 3, 2006 #4 Re: Grease on Prop? it the lower unit oil good i would do a presure test on it
sloopy Commander Joined Jul 12, 2002 Messages 2,999 Jun 3, 2006 #5 Re: Grease on Prop? maybe the mechanic who last worked on it had greasy hands?
OBJ Supreme Mariner Joined Dec 27, 2002 Messages 10,161 Jun 3, 2006 #6 Re: Grease on Prop? If it's black and gooey looking, most likely from exhaust and nothing to worry about.
