Evinrude fuel mixture
cflucky
Just bought a 25ph evinrude. Not sure of the year but the boat was a 1989 so that is close. A decal where you plug the gas line in indicates fuel mixture of 100 to 1. Can that be correct as most mixtures seem to be 50 to 1.
ezeke
Re: Evinrude fuel mixture
OMC tried that and gave it up quickly. Use 50:1 87 Octane Gasoline to TCW-3 Oil.
Darren418
My '88 48 SPL also calls for 100:1. I've heard that 100:1 is ok *IF* you use your motor regularly and avoid any prolonged operation at or near full throttle. Is this true? Also, is it ok to run at a compromise mixture of say, 60:1 or 70:1?
ezeke
Where did you hear that, Darren?
JB
If the manufacturer says to ignore the sticker and use 50:1 it doesn't seem like a tough decision to me.<br /><br />Junkyards are full of outboards that used to belong to people who thought they knew more than the people who made them.
Darren418
You make sense, JB & ezeke. I've heard that from other boaters at the ramp and on other forums. For the record, I do always run 50:1. However, or OMC to ever recommend 100:1 there must have been some research/experimentation done by them to support that initially. 50:1 is probably the "least common denominator" mixture that would keep everyone safe under a wide variety of operating conditions, but I was just wondering if there were some specialized situations where 100:1 might actually be ok. If we all run 50:1 anyway, this discussion is, admitedly, mostly academic.
