I hooked up the ammeter to the 2 10 ga wires and the meter goes to the max and the motor sounds like there a heavy draw on it .....I reversed the wires and it maxes out the other way with the same draw on the motor.<br /><br />I have a diagram and the wire that goes to the rectifier side of the box also has a short lead going to the ignition switch s post....any ideas what this might be.<br /><br />I has a old dash panel from a old Lyman and hooked it up a few weeks ago and it seemed to work fine....it was a different motor but the same box.
