I have a 65 aerocraft with a lark IX , there's a <br />shaft off the throttle that controls the timing and throttle blade, but the adjustment screw came loose and the throttle shaft came out of adjustment so when under full throttle the boat <br />will not get up to speed, i've tried setting the throttle wide open, then setting the shaft wide open and so on but i cant seem to get it right.<br /> <br /> the motors idles nice and runs alright like this but the timing just isnt advanced correctly. Any <br />help given would be greatly appretiated, thanks
