tkcenterline
- Jul 19, 2004
- 23
I have a great good running motor with all of the original parts on it. It was my Dad's motor. I still use it to this day and ever had a problem with it. The Fuel pumb OMC (#0382224) went out. I wanted to keep all the original parts on it. So instead of buying a new pump, I bought the rebuild kit. It came with all of the gaskets, spring and menbraines. However no instructions. Looked simple to fix. I took the fuel pump off of the motor which was very easy, by loosening just two screws. Then, I went on to take apart the sandwitched fuel pump parts and place them in order on my work table. However, while I was carefully laying it out, I hit the table and as you can guess, all the parts got mixed up. Nothing was lost, other then my memory, cus I am old now. So please help. Does anyone know the order of how to put this simple pump back together again. This pump seems to be a standard fuel pump for all smaller Evinrude/Johnson motors. If you had some kind of diagram or know where I could get one on the net It would help!! Thank you.
