Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
See more
See less
WOT Speed
  • WOT Speed
    What is the top speed you should get at 5500 rpm with an Evinrude 75hp installed on a 16ft deep v hull boat. Engine sounds great but seems as though its not getting everything it should. Not sure of the prop specs.
    Re: WOT Speed
    There is no specific predetermined top speed.Only estimated as each rig and setup is unique unless compared to exactly the same .Assuming that a 16 footer deep V design fiberglass hull with a 13 3/4" X 15" prop at 5500 rpm ,my guess would be around 34-36 mph in mild chop with engine trimmed out.
    • #3
      Re: WOT Speed
      Thanks, I'm getting max speed of 28 in fresh water. I know I'm getting a good spark on each cylinder. Just changed one coil and the rest are good. Could timing be my problem? Always seemed to travel faster in salt water! Is this my imagination?
      • #4
        Re: WOT Speed
        I notice better top end performance in salt water as well.No mystery there.Specific gravity of salt water is different from fresh.In order to determine whether you have or don't have a problem with engine rpm performance ,one would have to know what diameter and pitch prop you are currently using and whether the engine is et at its optimal height on transom(ie setup).
