This is my first post to a well browsed forum. I would like to thank the many posters and the moderators for a well kept site.<br /><br />I recently purchased a small fishing boat with a 1977 Evinrude 35. It was quite evident that this boat had been well maitained.<br /><br />Problem:<br /><br />I used the boat 3 times without incident, the 4th was more troublesome. My son and I motored for about 15 minutes and stopped for a bit. Started again and the boat started to hesitate, soon the choke was necessary to keep running, then..... row, row, row your boat slowly down the stream. Luckily half way back a few lads were kind enough to offer a tow.<br /><br />Solution:<br /><br />Before dumping a large amount of money into it I researched the forum and ended up with a carburetor kit and a manual.<br /><br /><br />Findings:<br /><br />The carburetor was extremely clean when I took it off, and I thought, just my luck, the problem may lie elsewhere. I stuck with it and rebuilt the carb. The boat now runs flawlessly. The only things that stood out in the rebuild is that the float was not adjusted correctly and the float needle may have been sticking. The rebuild kit had a spring clip for the needle to ensure that it drops as the float does.<br /><br />I thought that I would share this, in case others may get some benefit from it.<br /><br />Thanks for the help.<br /><br />Dave<br /><br />p.s.: The next project is a lower unit seal kit and water pump rebuild.
