kaboodleschnitzer
- Mar 17, 2006
- 1
Gidday<br />I have a 1976 johnson javelin 85 hp on a 5.2 express cavalier. Until recently it was happy cruising at 34 knots. I slowed to trolling speed then when i tried to accelerate i could not do more than 6 knots. A fuse had blown and the moter was running on two cylinders. The fuse was replaced and the power unit that controls the ignition system was replaced.<br />Next time out the same thing happened. This time I replaced the fuse and imediately had full power again on all four cylinders. This has now happened two more times.<br />Today the motor just lost power when cruising at about 28 knots. Replacing the fuse did not restore the power. <br />The fuse seems to blow when I adjust the trim while travelling. <br />Any clues.<br />Thanks Evan
