HI, Im new to boating, and just bought my boat last year. I have a 1991 lowe deep v 17ft. with a 1991 johnson 70. Towards the end of season last year I started to notice my voltage on the gage was running up around 16-17 volts at times. Then their was a couple times when the 20 amp short fuse in motor would blow. It would sometimes blow when I would put key in ignition and turn it to accessory position. Then go to start and their was nothing. motor wouldn't turn over no power trim. I would replace fuse sometimes it would blow again right away sometimes it would start up and be fine for an hour, sometimes a couple days. Then sometimes it started blowing when I was in water running and I would trim motor. Well season ended. I hoped when i pulled boat out this year it would be fine. wrong,,,The first day I got boat out ran fine for 1 hour. next day blew right away. went thru 5 fuses blowing them as son as i put key in and turned just one position. Is their anyone that can help me? will appreicate very much<br /> tj 269-208-9736
