evinrude lower units.....??..
i have a 1983 35hp evinrude with a broken lower unit....can I use the lower unit from a 1978 35hp evinrude. both are longshafts :confused:
D
DJ
Guest
Re: evinrude lower units.....??..
If they both have thru hub exhaust, yes.
D
DJ
Guest
Thru hub?<br /><br />The prop is basically a cylinder with blades attached.<br /><br />Non-thru hub. The prop will have a cone shaped item attached to the back side with a cotter pin.
