Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
evinrude lower units.....??..
  • evinrude lower units.....??..
    i have a 1983 35hp evinrude with a broken lower unit....can I use the lower unit from a 1978 35hp evinrude. both are longshafts
    Re: evinrude lower units.....??..
    If they both have thru hub exhaust, yes.
    • #3
      how can you tell if they both have thru hub exhaust?
      • #4
        Thru hub?The prop is basically a cylinder with blades attached.Non-thru hub. The prop will have a cone shaped item attached to the back side with a cotter pin.
        • #5
          thanks for the help
