1989 J50TLCEC<br /><br />I want to install one. There is a plug on the exhaust cover located at the top and the tell tale is connected at the bottom. Would it be better to relocate the tell tale to the top and install the pressure line at the bottom or just install the pressure line at the top and leave the tell tale where it is? Or is there another way I should do this? Thanks
