Pressure gauge installation ?
ob15
1989 J50TLCEC<br /><br />I want to install one. There is a plug on the exhaust cover located at the top and the tell tale is connected at the bottom. Would it be better to relocate the tell tale to the top and install the pressure line at the bottom or just install the pressure line at the top and leave the tell tale where it is? Or is there another way I should do this? Thanks
ob15
Re: Pressure gauge installation ?
Maybe I should have posted this under outbaord non repair. If so please move.
Dhadley
Either way is fine. Or you can T into the indicator line. The T should be in the gauge kit.
reeldutch
where can i get a waterpressure kit for a 1990 evinrude 115hp.<br /><br />sorry to ask
