I have this (1996) 48 hp Johnson, Great motor! I have a question Regarding my remote control on my console. This is a Johnson command center remote & is older than the motor. I suspect about the middle 80's. When I first crank the motor I raise the fast idle arm, BUT it does not increase the throttle for fast idle cold start. So it is a little hard to keep motor going when it's cold. Lucky for me, this motor starts easy. WHAT IS THE BEST WAY TO ADJUST THE FAST IDLE? I took the throttle shifting arm & side cover off. AND could find no adjustments there.<br />Any help out there?<br />Thanks !! JACK
