Re: old fuel - 2003 175 hp johnson
No pump in the fuel tank. Disconnect the fuel at the engine and use the primer bulb to start a siphoning effect. Siphon the fuel into drums on the ground. You may have to run an extension on the fuel line to get it lower than the fuel tank so that it drains properly. Empty the fuel into drums and use it in the lawn mower or other power equipment. Old fuel is a whole world of hurt in a high performance engine such as the 175 Johnson. If the Engine has been sitting for 2 years than the crabs will be dry except for a little oil and should not need cleaning out. Empty the tank, than add a little fuel conditioner than refill the tank with fresh fuel, ensure all your oil and fuel lines are in good condition, prime both the oil and fuel feeds and you should be fine. May be a little smoky for a few minutes until the excess oil in the carbs has cleared.
