Re: Evinrude 57 18hp starter/bracket to 68 18hp?
Sorry I'm so slow to respond everyone.Granddaughters DO take priorities whether any man can EVER!! say what they want about females.<br /><br />Seaking15, Yes, it is mounted the same. No, I have no pics available, but the bracket you will replace has all the same bolt holes as the one you will remove that mount it and anything AFT of the starter motor. This should clear up any question of compatibility that I am understanding in the posting. I also have a 40 hp with the bottom bracket that was mentioned, but I believe, as Paul said, that the 18,20,25 horse all interchange. Also, the hole that the kill button is mounted in is shaped to fit the wiring harness plug-in and the wiring harness is good to 68,69?? Works on my 67 anywho!!
