Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
1 of 2 < >
SITE MAINTENANCE
The iBoats Forums will be down for maintenance starting at 10 AM MST on 12/16/2017. The estimated amount of downtime is 3 hours (we are expected to be back up at 1:00 PM MST). Thanks for being a part of the iBoats community!
2 of 2 < >
3. Do not take over someone else’s topic (aka hijack) with your own question, even if it is similar. If you have a question that has not been covered to your satisfaction in the archives, it is always best to start a new topic of your own.
5. By starting your own topic, you will receive the maximum number of views by forum helpers that may not even notice your question when it’s posted at the end of someone else’s topic. And those answers will be specific to your particular issue.
See more
See less
motor (50 horse 1980 eninrude) questions
  • motor (50 horse 1980 eninrude) questions
    HelloPicked up a boat with an evinrude 50 horse E50ELCSR I think 1980. With 2 people no prob with 4 wouldnÂ’t plane and was very slow. The trim was back as far as it goes toward the transom. Does this mean not enough power or something else? Does anyone know if this motor has a good reputation? The boat sat for 2 years and started right away probably a good sign. It seemed to use a lot of gas for only 20 min. in the water. Any suggestion?Thank youRob
    Re: motor (50 horse 1980 eninrude) questions
    roboat,does your boat have a rating plate on it? If it is rated for 100 HP or more,the 50 won't move it very well with that load.If it's rated for 50 HP,but the 4 people weigh in at 325 lbs.each,same thing.Most boats seem to be rated for 6 people,but they have to weigh about 130 lbs. each.Go figure.DHP
    • #3
      that 50 is a pretty weak engine. i have 2 of them.its a 2 cylinder.what do you really expect froma small 2 cylinder. sounds normal
      • #4
        Two of them ?? great combo for a 15 foot Whaler.Only one,buy a 13 foot Whaler.YEE HAWDHP
