Re: 1984 Johnson 175 hp Seahorse
No truth, always use a thermostat.<br />If running without thermostat, the motor will then work at too low temp.<br />That meens the clearens between cyl wall and piston is always too big, and the piston rings, will also have too big clearens.<br />This will give you more dust and sod when the motor is running. And after a while, there will be too mutch dust and sod around the piston rings, whitch will give you lower compression pressure. And in the end the motor will not start.
