Re: Hot start problem on 2003 Johnson 150
I see a lot of hardstarting when cold, Im sure this is lean mixture. Other problems with this engine in the sensor and power pack. The OMC tool that check the sensor is junk. One poster explained how to check sensor with a scope. The sine wave must have square corners, if the corners of the wave form is squiggle, the engine will misfire, stumble, stop running when hot. The coils burn thru the insulation and arc to the metal plate between the pack and the coils, all of this arcing not caused by poor coil insulation, I had some discussing about this pack with Rapair Monday while I was touring the Rapair plant.<br /><br />The vapor seperator has a diaphram pump to remove the vapors, if the pump not working, you may have vapor lock after hot soak.<br /><br />Newer ignition switches also cause problems, there was at least one recall and one service bulletin on the switches, and I still think they are junk. I also beleave that there still is a quality control problem with some replacement parts. Wrong part in right box, right part right box defective part. Im rambling now, but if DH or Rodbolt cant fix it, call me.
