Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Setting the points on a 4HP evinrude
  • Setting the points on a 4HP evinrude
    Position of the throttle when setting the point? Motor will not run at more than half throttle.
    Re: Setting the points on a 4HP evinrude
    Align the flywheel key with the fiber rubbing portion of the points, then set the points so that a .020 feeler gauge will pass thru the gap but a .022 will not.If you're saying that the engine wants to dies out when throttle is applied, that's usually due to a fouled and/or improperly adjusted carburetor.
    Our Questions Require Answers... If You Refuse To Answer Our Questions... How Can We Answer Yours?
    • #3
      Thanks for the help
