The motor would not run except low speed...after adjusting carb, checked plugs, one had the gap closed. Put in a spare plug and it run great. I took it out the next day and it would not run except at low speed again...plugs were fouled but they were gapped. I put new plugs in but still no change...low speed only. What is the gap suppose to be for j4c champion. 1966 Johnson 33hp model# RXE-14?
