nashville_roy
- Aug 23, 2005
- 3
My original problem was the tachometer not working. Using some of the information in this forum, I found that the rectifier was open. I also noticed that the voltage across the battery only varies from 12.6 to 12.7 from idle all the way to WOT.<br /> After replacing the rectifier, the tach is now working but the voltage situation has not changed. Any suggestions where to look next?
