Hi, I have a 1993 Electric Start Johnson Sail Master 9.9Hp. Model: J10SELETM, Any Idea where the Battery cables go to? I can see the red wire connected to the starter and to the rectifier, I also see the black Ground wire, I can see all 3 wires until they get to under the carburetor there, it looks like they go thru a hole and wala they disappear and there is no wire to connect them to a battery? Is there any special plug on this motor? Please help Im getting crazy with these wires. <br />Thank you
