spanpitts57
- Aug 1, 2005
- 11
i just picked up a SpanAmerica 15' with and evinrude lark 35 (#25532 15342). the engine ran fine 13 years ago (i rode in the boat back then) and was stored inside. i went through and cleaned up all of the electircal contacts and the starter and electric choke operate. it's looking like i get no spark though, i didn't see any on the fresh plugs and my timing light didn't blink. i just found out today that parts are scarce for this engine, so i want to find out if it's worth putting money towards. <br /><br />first question is what kind of compression should i see on cranking? pull starting feels good, but i have no frame of reference for an outboard. i don't want to put all this effort into a worn out motor. <br /><br />next is if there is an ignition kill circuit? i have a seloc manual on the way but i won't get it until next week. after fresh plugs (champion j6c), what is the next thing to check for spark? <br />i found new coils from sierra coil (47-5181) for $15, are they direct fit or will i need to custom fit them? <br /><br />Is there anything i should do to the cooling system to make sure the water passageways are clear? <br /><br />I'm looking forward to getting this beast (if you can call it that) out on the water. any info is much appreciated. <br />Thanks,<br />Mike
