ralphmorgan
- Jul 30, 2005
- 6
Can anyone give me some ballpark figures on what the water pressure should be on a 1996 Evinrude 112 HP. I checked it today and it shows 9 lbs at 3200rpm and 14 lbs at 4400 rpm. Is this within range? The water is strong out the pee hole, even at idle. At idle the water pressure is about 2 lbs, that is in the water not on a flush device and water hose. Any help will be appreciated. I could not find an answer in the FAQs. Thanks
