You may have this covered in a FAQ somewhere but I don't have time to research for the correct answer.<br />I have an 1974 Evinrude 135 HP v4 (135489b) and I have to set Maximum Spark Advance. I do not have access to a wheel and tank setup but I can take this to a lake and test on a trailer.<br />My book reccomends 4 deg at idle and 22 deg at 4,800 RPM and a max RPM of 5,200.<br />My question is this: If I set the timing while the boat is tied to my trailer should I set it to the specified 22 degrees or should I shoot for a lower number because of other unknown variables? If so then what number should I shoot for? I'm looking forward to putting this beast back together this weekend, timing it out, and giving it a good run. Thanks for any input.
