Re: Prop for 2005 175 Evinrude DI
It might. But just to see have the dealer put on a 17 or 15 to test. If the r's only go up slightly you'll know the computer is whats stopping it.<br /><br />Once the motor is broken in you may want to look at set up. especially if the motor is mounted all the way down. And a lot depends on what type prop you have.
