Pinion gear needed 40 hp Evinrude
Merrill
It all started with a little oil leak so I decided to install a seal kit in my 1962 Evinrude. I found lots of metal hunks while in there. The pinion gear is shot along with a thrust washer, could use a new drive shaft also. Anyway, I need a pinion gear PN 0308692, anyone got one? I'll check Ebay next. I found a 50 hp unit with boat in the local paper for $1,000 maybe I should get that instead? ;)
CATransplant
Re: Pinion gear needed 40 hp Evinrude
Check with an outboard wrecking yard like tcoutboard.com. That's your best bet for this.
