Re: Johnson ocean runner 225 hp heavy smoke
Listen to the "VRO" pump while the motor is idling in the water, not on a flusher. If you hear a rapid clicking sound, you may have an air leak in the fuel system, or possibly a bad VRO. To confirm, temporarily hook up a piece of clear fuel line to the pump inlet fitting and run the motor for a while. Anything more than an occasional small bubble is something to be concerned about and will make the VRO pump the same amount of oil, but for a smaller volume of fuel, creating a smokey mixture.<br /><br />Most healthy "VRO" pumps will click (pulse) about once every 3 to 5 seconds at idle up to about once a second at top speed.
