Can anyone tell me if 1977 75 HP Johnson Stinger uses the same fuel pump as the same engine year and model without the Stinger designation. I have been on line looking for either a repair kit or new pump and find that every site where the kit is available for this model engine (75ELR77, but mine has an S after the 77) has components entirely different than mine. None of the several different kits available for any year and/or model are similar to mine. I am willing to buy a new pump but want to make sure I get the right one. I have been having problems with the engine stalling when the throttle is opened. It has been in the shop 3 different times and carburators rebuilt, new plugs, one coil replaced, rectifier replaced, fuel line, bulb, fittings and gas tank replaced.Compression and fuel pump checked out OK. At first you could "nurse it"at slow speed for a few minutes and gradually open the throttle to full speed. It has progressively gotten worse so it won't run at all, except at idle and slow speed. I want to change the fuel pump to see it that solves the problem. Thanks for any help you can give.
