Taylor/man
- Jun 20, 2005
- 4
I have just purchased a 48 special Evinrude motor from a friend...model no. E4ELSLESA...the problem is that the tilt/trim drifts leaks down once it is trimmed...The problem did not occur until he change the fluid on the tilt/trim unit...I am patiently waiting for the local Evinrude dealer to get me my manual to correct..but... I was hoping someone could tell me how to properly bleed the tilt/trim..I noticed two screws on the unit, one above the other...are these the bleed in the extended and retracted positions? Also, what fluid should i use? This forum was very helpful in assisting me in getting my stuck steering problem...I want to get back in the water, but my dealer is dragging his feet...thanx
