Hello. I'm new to the site, so please pardon my inexperience.. I have a 1972 Johnson 65 horse outboard (model 65 esl 72s). The motor was run a couple of times last year, but will not even crank over now. I have replaced the solenoid (I can get the motor to crank by jumping the solenoid), and now think the problem is in the neutral safety switch. I have tested the ign switch, and have power coming out when the key is turned to the start position. Can you advise how to test the neutral safety switch?
