Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
Year of 9.5 hp Evinrude Sportwin
This topic is closed.
  • Year of 9.5 hp Evinrude Sportwin
    I'm considering purchasing a 9.5 hp Evinrude Sportwin. The seller has listed it as a 1973 model year. The model number is 9322B, and the serial number is J 07865.1. Can somebody please verify the year?2. Any problems in particular that I should look for with this model and year? (and I plan to do a compression test when I go to look at it)THANKS
    Re: Year of 9.5 hp Evinrude Sportwin
    Yup. That's a 1973, P51D.The only "problem" I know of is sealing of the exhaust. If the exhaust leaks under the bonnet the engine wont run with the bonnet on.Easy to recognise and easy to fix.
    sigpic
    • #3
      hi , i'm considering to buy the motor , see link
      it at the dealer for maintenance, so the seller can't ive the numbers, but can u recognize something on sight?
      i looks very nice
      btw how can i post a new topic ?
      link ;
      http://www.kapaza.be/Watersport_en_b...ude_9_5pk.html
      • #4
        Take the cover off, grab the top of the flywheel (not running) and give it a good wiggle back and forth. If it flops around, the motor mounts are shot.
        • #5
          If, instead of hijacking a 4 year old thread you just start a new one of your own you will get a lot better response.
          Open the forum. Look at the upper left. Click on "create new post".
          sigpic
          • #6
            i looks very nice
            link ;
            The motor appears to be a 1967 model. It looks clean, which is a good sign. For 1966 they changed the latch for the cowling so that it was now a lever on the lower cowling, not a knob on the upper cowling. They also improved the motor mounts for smoother operation, and the carburator got some fine tuning for better economy at part throttle. Naturally a 1967 model carries forward with all those improvements.
            Run 50:1 in it.
            Cam Milne
            1950 Johnson 5 - TN-26
            1955 Elto 5 (Gale 5 based) - 5D11E
            1956 Eatons Viking 5 (Gale 5 based, incomplete) - 5D12V
            1958 Johnson 7Ĺ - AD-12
            1967 Johnson 9Ĺ - MQ-13
            1971 Evinrude Yachtwin 4 - 4136D
            1976 Johnson 15 - 15R76
            - all from freshwater and built in Peterborough
            "None of us is as smart as all of us"
            • #7
              I have a 1973 and it does have a few differences than the one in the picture. My upper cowling is white and the face plate (where the knobs are) is basically blue and the low speed idle knob on mine is different as well. I am not sure what that red wire is at the back of the inner cowling either.
              • #8
                start new thread
                FLORIDA GATORS
                TEBOW Country
                Please, NO PM's (Private Messages) regarding boat/engine problems. they will not be answered.
                That is what these forums are for. Post your questions, in the appropriate Forum.
