I DID IT!!!! WAS EASIER ONCE I KNEW WHAT I WAS TO DO TO REMOVE , STILL A LITTLE TRICKY...
WELL I DID IT BECAUSE MY WATER WAS NOT PISSING OUT WATER AND WAS THROWING THE HOT ALARM. WELL NOW IT IS PISSING OUT WATER BUT IS A LITTLE IRREGULAR REAL HARD THEN SOFTER BUT CONTINUES TO FLOW, WATER GETS WARM THEN COOL.. THE ALARM STILL GOES OFF THAT SAYS HOT BUT THEN GOES OFF BUT LIGHT STAYS ON.. MOTOR SOUNDS GREAT. I REPLACED THE PLUGS,THERMOSTATS, WATER SPERATOR AND CHANGED THE LOWER GEAR OIL... ALL THAT AND THE ALARM STILL GOING OFF. IAM CONCERNED ABOUT RUNNING IT AND WORKED VERY HARD. WATER IS FLOWING AS I SAID IRREGULAR. i AM NOT LOST ON WHAT TO DO AND OUR STRIPPERS ARE STARTING TO COME IN. PLEASE ADVISE AND THANKS FOR THE REPLIES THAT IS THE ONLY WAY I COMPLETED THE JOB
