Hi, I am working on a 1955 Johnson CD-12. I'm in the northeast so its a little slow going due to the weather. I was thinking since I have the carb out for tune up maybe I should attempt to covert the fuel line from the old pressurized tank to the current single line with a pump bulb. Are the old pressurized gas cans really that troublesome and a fire hazard? The can I have looks its age. Would it be worth it to make this change? and if so, what parts would I need and how would I go about doing it. Thank you in advance.
