hardwater fisherman
- Mar 19, 2010
- 1,725
Does this cam follower sleeve look worn down? I have it set that the throttle plate starts to move at the first of the 2 marks. And when the mag plate goes around and hits the stop the throttle plate is fully open. The reason I ask this is because I have not seen one of these sleeves before. I think all of my other motors have rollers or just a solid plastic cam follower.Edit I had to push the cam follower back very far and tighten the screw to make contact with the mag plate cam.
