Cadillac-ack-ack
- Dec 1, 2017
- 104
Just got going on my '62 Lark rebuild. In the take-apart mode still and as this is a winter project not a rush. Pretty experienced with 4 stroke auto and bike engines and a little with 2 stroke yard stuff like small chain saws, weed eaters etc. Always thought 2 strokes were pretty simple and yes they may have fewer parts overall but I'm discovering this old Evinrude is a pretty sophisticated piece even at 55yrs old. Finding a lot of note taking is a good idea as it seems there is an order in what one takes off (carb doesn't come off unless starter is off and that doesn't want to slip over it's studs until the recoil is off). This, I imagine can be frustrating come re-assembly time if one goes out of order. The only real diagnosis I've come to is a bit of scoring on the exhaust side of both cylinders, more on the bottom hole than on the top. Measuring with a bore gauge, though, showed no out of spec taper or localized wear even in the vicinity of the scoring itself, at least as far down as the ports. Experience with cylinder scoring in the past leads me to believe the aluminum pistons probably took a much bigger hit. They are not out yet. Looking for oversize was futile but I did manage to find two NOS standard pistons on ebay and two sets of standard rings. I feel a minimum honing of the cylinders together with new pistons and rings will be just the ticket even though all the score marks will not be gone. I really see no other alternative other than a search for a new block and I really don't want to go down that route. - Pete
