thatone123
Banned
- Mar 7, 2009
- 707
Well, I am finally getting up the nerve to tackle putting 2 e-tec lower unit gear sets back in the cases. Chickened out or found excuses and started and stopped a half dozen times why not to go thru with it. I got the standard gear case gears in the case but here is a stupid question. How do you get the pinion gear in the case? I have the factory manual and they tell you how to put the nut on and etc., but I don't get how to fit the pinion gear in the case after sliding the gears in the case? Do you put it in ahead of the gears? It seems you need 3 special tools to do this job or is there a way to get around that? I have to take the gears out again anyway as to get the drive shaft bearings back in their race needs to be done with the gears out it seems.
