healey8390
- Nov 19, 2010
- 215
86' 110 Johnson, had to take motor off to do the steering/tilt tube. Was on the ground and got flooded during Harvey. We were one of the few houses in the area to not get flooded so if the motor is shot we are still blessed.
The water went about half way up so I didn't think it got into the internals at first but when I checked it did. This was a few days to a week later mind you. I took the plugs out and pulled a rope to expel what I could and then put trans fluid in the cylinders and turned the flywheel. I had a friend help my put it on the boat and took off the carbs and cleaned really good. It was a mother to get started and would idle good but would bog when giving gas. I noticed the coils were 'melting' onto the block so I ordered four new. It ran better but when I gave it gas it didn't have the power it used to. I felt the heads and the left side was to hot to touch and the right side wasn't. I tried running it with only the right side plug wires on and it wouldn't. Luckily, I had an extra power pack, put it on and it runs like champ seemingly. However, it has exhaust sludge leaking from behind the prop when i turn it off. It seems excessive and makes a puddle. I haven't had this problem before that I remember. The sludge feels gritty as well but doesn't seem like metal from what I can tell. Has anyone had this issue of sludge? Also, if the motor runs good on the water should I assume it could blow at any moment since it got water in the cylinders??
