I have a 1996 30 hp Johnson 2 stroke. model J30EEDE with NO VRO. it does not look like it has ever had one either. I have been using the boat for the past few days with no issues. while trolling a steady alarm went off and the low oil light lit up . I shut down the motor waited a few min started and alarm still going off. repeated again no alarm but low oil light was on. This boat has the standard 4 light gauge that goes through all 4 lights and an alarm when you first start it, all work fine for my previous trips. Now when sitting in my driveway turn key to on position goes through system check with alarm , but when it gets to low oil light it either stays on or flashes with no pattern. I ran the motor in a bucket of water and starved it for water and the temp light lit up as it should. . I shook wires harness and squeezed it all over to check to see it the light changes , even jiggled the key to see if any changes can be seen. even wiggled wires on engine with no change. have had no luck. looking for advise ???????
