Hi All,
Replacing a water pump seems doable, but I've not been able to so far...
Looking for replacement water pump for my 1995 evinrude 70 hp at the evinrude web site, I am led to kit #
part number 93 on the gearcase diagram.
So for 1995, it says use 438591. Ok, on ebay, there "new old stock" showing this kit has a three bladed impeller. On another web site there is a statement saying 432955 (6 bladed impeller) replaces 438591. My service manual (which is p/n 503149) shows a three bladed impeller. The Seloc manual seems to suggest 6 blades. Going to various sites and looking at "E70TLEOR" (the engine's model number) leads me to 432955.
I used the Sierra 18-3387 (the kit with no housing) and it failed, I want to order the right part for my next attempt. One very obvious difference from OMC and Sierra was the original water pump used a cup that the impeller sat in. The cup then sat in the housing. The Sierra kit provided a bottom plate and a side ring to form the same cup shape. These two pieces never seemed to fit very well into what was most likely the original housing.
Any ideas on what part I need? Has anyone had good luck with the two piece cup of the Sierra Kit?
Thanks
0436957 | WATER PUMP REPAIR KIT, (Includes impeller hou ing). FOR 1995 & NEWER MODELS USE 438591. FOR 1994 & OLDER MODELS USE 432955. |
Thanks
