ib18
- Mar 2, 2013
- 489
what is the minimum voltage of a starting battery to start a Johnson 90 v4 outboard?
Hi, I took my boat out fishing this weekend. It started after 3 cranks so we left the dock. Got to the stripers fishing hole, and shut the Johnson 90 off and using the motor guide 24 volts 75# wireless trolling motor. And started the Johnson 90 again after 2 cranks to go bottom fishing when surface stripers dissipated. We found the spot and started to catching white perch immediately. Used trolling motor a couple times. Time to head out to deeper (60 feet) spots to live lining the small perch. And it started without any problem. Troll with 24 volts a little more and fished. At the end of the day, we were ready to call it a day. But, I could not start the Johnson 90 after 3 cranks. I didn't try starting Johnson 90 again fearing it could drain the batteries down and we would not be able to use the trolling motor to go home. It took us about an hour to troll back to the dock at 2+ miles per hour under 1 foot of wave and 5 knots wind.
My 2 deep cycle marine batteries are rated 29HM from Advance Auto Parts with 675 cold cranking amps, 840 max and 210 reserve capacity.
Can't wait to mount my kicker motor - Honda 8 hp 4 stroke.
