1972 Johnson Winterizing
CeeJ1791
I have a 1972 Johnson 50ESL72R Powershift 2, can?t seem to find a manual to purchase anywhere. What type of lower lube do I need? Read somewhere that Old Johnson?s need Type C lube for electric shifter motors. Does this apply to my Powershift 2 motor?
jbuote
Not an expert, but I believe the "PowerShift II" was on 1973 and later..
​1972, if I'm not mistaken, is Hydro-Electric shift in which case you need Premium Blend or Type "C" lower gear oil. Not all Type "C"'s at the same though I've heard, so be sure it's specifically for Electric Shift.
​If indeed you have "PowerShift II" I think the engine would be a 1973 or later, which is hydraulically assisted manual shifting (not electric) then I still think you need premium or Type "C", but doesn't have to be specifically for electric shift.
​If your model number you posted is accurate, then pretty sure you have Hydro-Electric shift, and maybe the remote is a PowerShift II type that was rigged to work...
​Do you have shift buttons or anything for shifting the gears?
​EDIT: Found model numbers 50ESL73R, 50ESL72C, but can't find a 50ESL72R.....
Could you double check your model number?... Just in case?? LOL
CeeJ1791
Misread the model number..it?s 50ESL73R so 1973.. thanks for your help
jbuote
Yup... That makes sense.. lol...
​So Premium Blend, or any Type "C" is what you need... That much I know..
​There may be suitable substitutes as well, but I don't know what they might be..
Glad to help! :)
